TPI torque settings
Old Mar 23, 2006 | 06:27 PM
blackbeauty's Avatar
Car: 1989 Trans Am
Engine: 1989 305 TPI
Transmission: 700-R4
Axle/Gears: 2.77 10 bolt
TPI torque settings
Hi all,
Could anyone please tell me or point me in the direction for the torque settings on a TPI engine? I'm after settings for the plenum and runner bolts, throttle body etc and various devices like IAC, temperature sensors etc etc. I googled thirdgen.org but didn't find anything.
Old Mar 23, 2006 | 07:12 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I believe 18lbs
Old Mar 23, 2006 | 07:28 PM
Car: 1989 Trans Am
Originally Posted by Mkos1980
I believe 18lbs
For what exactly?
Old Mar 23, 2006 | 08:09 PM
V6canvas's Avatar
Car: 1989 Trans Am GTA
Engine: Stock LS1
Axle/Gears: 3.70 9 bolt
On those bolts, I've always done it by feel. basically just snug them down, then give it a little bit more. Obviously with plastic parts a bit less is appropriate than on all metal parts. For example on the runners, throttle body etc you can crank them pretty hard (you are using hand tools here right? don't be using 1/2" drive impact guns ). Give any plastic things (sensors etc) an extra 1/4 turn after they get snugged.
Old Mar 24, 2006 | 06:50 PM
noagenda's Avatar
Car: 1987 IROC-Z
http://tpiparts.net/tpi_torque_specifications
should provide you with all the numbers you need...
Al
Old Mar 26, 2006 | 05:44 PM
Car: 1989 Trans Am
Awesome, thanks for that.
Vintageracer
Jan 10, 2020 05:33 PM
Fast355
Dec 2, 2016 06:33 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
Sanjay
Aug 12, 2015 03:41 PM
gwade12
Aug 8, 2015 08:17 AM
