LT1 swap people i need..
Old Mar 24, 2006 | 01:24 PM
1qwkta's Avatar
I need your help. I need somepics or diagram on how the vaccum tubes go, start from and go to were and what peices.
I'm and LT1 guy and i'm helping my friend finish what him and his grandfather swaped out. His grandfather dies in the middle of the swap but al we need on is the intake, coolant, distrib., plugs wires, little things,
but i'm lost on what sensors are what and were things go. i though i might be able to help but LT1 and TPi are different !
Could use some pics of the vaccum lines
Coolant lines, so i can mount the remote T-stat
were the A/C was, so i can put the pully system back, i don't know how it goes.
We don't want the smog pump either, so i think we need a delte pulley for that, or is there another way to route the belt?
please any help is good help
Old Mar 25, 2006 | 09:22 AM
erummel's Avatar
Car: 92 Z28
Engine: aint got no engine right now
Transmission: need one of those
Goto to http://lt1intake.com/files/update.htm and scroll down for the port locations for the hose connections as well as the hose routing for coolant
Goto to http://lt1intake.com/files/vac_hose_routing.html for the stock TPI hose routings to give you a starting reference point.
If you or your friend dont have a shop manual for the car you should get one. This will help tremendously. As for the air pump delete, your easiest option is to use the pulley delete.
E
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
