LT1 Injectors
Old Mar 24, 2006 | 09:17 PM
luke4907's Avatar
Car: '89 Trans Am GTA
Engine: TPI350
Axle/Gears: BW 3.27s
LT1 Injectors
Hey guys, so I've come across a set of LT1 injectors that I'm going to try in my car since I think my injectors are bad (lose fuel PSI way too quickly). I've got them sitting in a bowl of injector cleaner right now, and I had some questions. When I removed them from the manifold, there were indications of lots of rust. I'm talking about an extremely thin layer of rust at the very top of each injector.
Was this what the little fuel screen used to be, or is that deeper inside the injectors? Provided that I let them sit overnight and make sure they are all thoroughly cleaned, should they be OK to put in my car? Thanks
Old Mar 26, 2006 | 04:29 PM
Vader's Avatar
Soaking the entire injector may admit solvent (cleaner) through the electical connector and into parts of the solenoid coil that may not react well to it. You may want to dry them out completely, allow them to sit for a few weeks, then measure resistances to make sure you didn't dissolve any insulation varnish on the solenoid windings.
If the coils are still intact, you can either try them, or send them off for cleaning and evaluation. If you send them to www.cruzinperformance.com they will be flow-matched, and return with new inlet screens.
Old Mar 27, 2006 | 04:57 PM
luke4907's Avatar
Engine: TPI350
you can always count on vader for an insightful reply... thanks man! I have the injectors sitting out now, I think I might go pick up an ultrasonic cleaner from harbor freight and toss them in that for a little bit. Is that a good idea? I'll test the resistance again before pulling my intake off to install them. thanks
New2Chevy
Sep 28, 2015 12:35 AM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
92rsvortec350
Sep 10, 2015 10:54 AM
L0tuS
Sep 4, 2015 11:16 PM
