TPI part numbers
Old Mar 22, 2006 | 06:08 PM
blackbeauty's Avatar
Car: 1989 Trans Am
Engine: 1989 305 TPI
Transmission: 700-R4
Axle/Gears: 2.77 10 bolt
TPI part numbers
Hi all,
Could someone please give me the GM part numbers for the following...
Throttle body gaskets - for the plate that says "Tuned Port Injection" and the bottom gasket for where the IAC valve housing bolts on underneath
Mini torque bolts that bolt down the above mentioned plate and IAC valve housing
Torque bolts for the runners that go into the manafold and the plenum
The breather hose that goes from the right side rocker cover to the side of the throttle body.
Thanks!
Old Mar 22, 2006 | 10:26 PM
Vader's Avatar
Most of the TPI runner and base bolts are M8-1.25 x 30mm. There are a couple longer ones on the runners in the lower positions that fasten from the inside out, but I cannot recall their length with any certainty. They seem to be about 40-45mm.
The cheese head Torx screws for the TB cover plate are M4-0.7 x 13mm w/washers.
You can find the three-piece throttle body gasket kit just a couple hundred miles west of you on the "other" island, right here:
https://ssl.shoalhaven.net.au/usgmse...77436e93a1f2e3
The hose is nothing special. It's just a 1/2" hose about 150mm long from the TB to the molded plastic (hard nylon) tube that runs along the valve cover. The plastic tube fits to a 90° rubber elbow, which fits to the valve cover adapter fitting. You should be able to piece this together easily with commonly available emissions hose and fittings. Sorry, I don't have all the GM part numbers for the pieces.
Oh. I forgot the lower cover screws. I don't recall their size, but they are smaller than the top cover screws. I'd guess they are M2.5 or M3. you'll find out when you take it apart and break them off.
Old Mar 23, 2006 | 05:16 PM
Car: 1989 Trans Am
That's awesome Vader, thanks for very for that.
Old Mar 23, 2006 | 10:23 PM
Vader's Avatar
BTW - I got my hands on one today and checked. The TB lower cover/water passage/IAC housing bolts are NOT smaller. They just seem that way after they've eroded away. They should be M4-0.7 x 23mm. Stainless would be really good in this area, but whatever you get, make sure you get anti-seize compound and use it liberally.
It was the TPS screws that are ridiculously small.
Old Mar 24, 2006 | 11:30 PM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
The CCV hose from the right valve cover to the side of the throttle body should be a 10105287. As Vader suggested, I would try and piece together a suitable replacement if I were you.
Edit: The part number I listed is for a 90-92 TPI application. The earlier TPI engines used a hose set-up like Vader described. Here's some diagrams showing the difference, http://lt1intake.com/files/vac_hose_routing.html. What's the year of the engine you are using?
Old Mar 26, 2006 | 05:39 PM
Car: 1989 Trans Am
This is for a 89 engine. If I turned my rocker cover around the other way, I could probably use the 90-92 hose set up if I wanted. But I'll have a go at piecing something together.
Thanks guys.
Old Mar 27, 2006 | 12:58 AM
Vader's Avatar
If you get in a real bind (or Australia is closed) you can cut your own gaskets from these templates:
Old Mar 27, 2006 | 05:44 PM
Car: 1989 Trans Am
Thanks for that Vader. I managed to find some locally in the end, but if you'd posted earlier I would have used these instead of buying them. Not to worry.
1992 Trans Am
May 10, 2023 07:19 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
twest2k2
Aug 24, 2015 11:26 AM
TA8487
Aug 16, 2015 12:21 PM
armybyrd
Aug 10, 2015 09:23 PM
