fuel issues
Old Mar 27, 2006 | 10:27 AM
Teds92RS's Avatar
Car: 1989 Camaro IROC-Z
Engine: Lt1
Axle/Gears: Quick performance 9" 4.11
fuel issues
I had no fuel pump priming or anything. Replaced the fuel pump relay, the fuel pump, the fuel pump fuse, and the ignition module, still nothing. When I turn the key my fans come on, guages come on but no fuel pump priming..turn the key over and it cranks. Any other ideas?
~Ted
Old Mar 27, 2006 | 10:51 PM
Vader's Avatar
Did you check the fuel pump/ECM fuse along the right inner fender?
Old Mar 27, 2006 | 11:45 PM
Teds92RS's Avatar
Engine: Lt1
unfortunately, yes lol Someone on another board thought maybe VATS, but I have spark...doesn't VATS cut out fuel and spark?
~Ted
Old Mar 29, 2006 | 10:07 AM
Teds92RS's Avatar
Engine: Lt1
ok, VATS is out of the question, everything is fine there. However, I did notice that now my fuel pump fuse keeps blowing. I also noticed my connection for the alternator came off, which makes sense why when the car broke down I lost volts. If that wire coming off the alternator touched metal (which I'm sure it did), could that cause a short and fry something? I only question that because it's not a hot lead. I traced around wires from that fuse and don't see anything visible that would cause a short. At least my problems are narrowed lol
~Ted
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
Bryan F
Aug 18, 2015 02:28 PM
