MANIFOLDS
Old Mar 29, 2006 | 11:45 AM
bigmaciroc's Avatar
MANIFOLDS
i want to get a new manifold for my 85 iroc with 305 tpi, im sure what im looking at in the pics of these things, i want the upper and lower, if any one can help me with a company or brand i should use, or let me knoe what you are running. thanks alot
Old Mar 30, 2006 | 04:34 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Well you nned a base that has the holes drilled for the earlier heads. Edlebrock , Accel , TPIS ( cleaned up edlebrock base) . then runners you can get Edlebrock , SLP , ASM . Check the regular spots . Summit , jegs , etc
Old Apr 1, 2006 | 11:43 PM
cheese_kake's Avatar
Car: 1992 Camaro Z28
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
Id go Stealth Ram, or if you wanna keep the good looks of the TPI just port it, and if you have the time you can even siamese them yourself. But for pure performance HSR or ASM are what you need to consider.
db057
Jan 10, 2020 08:55 PM
sailtexas186548
Feb 17, 2017 03:07 PM
Chas91Z28
Oct 22, 2015 10:12 AM
86CamaroDan
Sep 29, 2015 10:08 PM
