87 L98 smog pump delete
Old Mar 29, 2006 | 10:45 PM
87iroczzz's Avatar
Car: 1988 IROC-Z
I was wondering if I can delete the smog pump on my 87 iroc L98 TPI. I can't find a delete pulley and wondering if there is another way i can do it. Any instructions or diagrams will help and if I can remove my cat without any problems.
Old Mar 29, 2006 | 10:48 PM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
there is a tech article at the home page of the site that tells you how to do it.
https://www.thirdgen.org/tech/serpentine.shtml
thats how to route the belt.
Last edited by maroon88iroc; Mar 29, 2006 at 10:50 PM. Reason: Automerged Doublepost
Old Mar 29, 2006 | 11:23 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
IIRC, '87 has the v-belt/serpentine combo.
v-belt for the ps pump
v-belt for the a/c (wraps 1/3 of the p/s pump pulley)
serp. for the water pump & alt.
v-belt for the air pump.
Remove the pump. leave the belt off.
Old Mar 31, 2006 | 07:26 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
Yes agreed. When I put my headers on my car, all that smog pump and piping went in the trash. It was just a V-belt. I didnt have to put a delete pully on or anything. Hardest thing to do was getting the smog pump lines off that wrap around the back of the motor. If you follow the lines from the drivers side....it wraps around the back of the motor and goes to the passanger side. Thats sort of hard to get off. I tell you what though, I put my headers on.....and it really cleaned up that motor compartment!
Old Apr 6, 2006 | 03:01 PM
josh_pete2001's Avatar
Car: 87 IROC
Axle/Gears: whatever stock is
Ive been wanting to remove that clutter from under my hood as well, but i was wondering if anyone has just removed the a.i.r. setup and plugged off the holes in the manifolds
Old Apr 6, 2006 | 11:28 PM
Jetmeck's Avatar
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
Yes there are plugs for the holes in the manifolds.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
italiano67
Dec 11, 2016 09:21 AM
BlackphantomZ28
Aug 21, 2015 07:12 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
