newbie question about TPI
Old Apr 4, 2006 | 10:20 PM
85LB9Z28's Avatar
Im sorry, very new...
what controls the TPI? is there a computer? isnt 85 too early for a computer? i was reading how to change TPI to carb and i didnt get it.. is it an overly hard job?
Please help
thanks
p.s. again im sorry for being so new.. owned my car for 2 days
Old Apr 4, 2006 | 10:51 PM
Vader's Avatar
Changing TPI to a carburetor for a street driven vehicle is generally regarded as a downgrade. The TPI will provide far more low end torque, fuel mileage, and general reliability than a typical carburetor installation.
Yes, there is a processor (Engine Control Module) which controls the injection, ignition timing, and various other functions. GM first had engine control modules on mid- late-1970s Olds and Cadillacs, and they migrated to almost all models by 1980.
BTW - Welcome Aboard!
Old Apr 5, 2006 | 09:59 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
I totally agree...Keep the TPI set up. The Tuned Port motor is nice!
Old Apr 5, 2006 | 11:04 AM
Leif-o's Avatar
TPI is great! Any kind of Fuel injection is going to have some sort of computer to control the injector pulses and to analyze all of the sensors to decide on how much fuel is needed.
Old Apr 5, 2006 | 11:21 AM
85LB9Z28's Avatar
thank you all,
im just thinking about a 355 in the future.. would it be hard to change it over?
Old Apr 5, 2006 | 11:45 AM
roachjuice's Avatar
Car: 86 Omni GLHT
Engine: 2.2 Turbo/Intercooled
Transmission: 5 speed
Axle/Gears: 3:85
all you would need is new injectors and a tune...
Old Apr 5, 2006 | 12:04 PM
85SILVERBULLET's Avatar
Car: 1985 TRANS AM
Engine: 383 SBC
tpi is nice but it has restrictions that a carb set up does not. you need to figure out what you are going to do with the veh and then you could make a decision. Street car w/ limited rpm (6000@most) =TPI any higher rpm is limited by runner size. anything above 6k I would use a single plane and a matched carb set up... just my 2 cents...
Old Apr 6, 2006 | 11:41 AM
Shagwell's Avatar
Car: projects.......
...Any kind of Fuel injection is going to have some sort of computer to control the injector pulses and to analyze all of the sensors to decide on how much fuel is needed.
Any type of ELECTRONIC Fuel injection has a computer. Mechanical fuel injection does not.
- Unless you're planning on going really wild, keep the TPI. Even at very strong street car, keep the injection stuff and switch the intake. - Or go DFI...
Old Apr 10, 2006 | 10:33 PM
firebirdowner89's Avatar
Car: 89firebird
Engine: 355 TPI
Transmission: world class T-5
Axle/Gears: 3.73 posi
yeah man keep the TPI there is so much potential for them and alot of people dont know.. i converted my firebird from carb. to TPI..
Old Apr 10, 2006 | 11:06 PM
chevy385's Avatar
Car: 93 Sub K1500, 77 GMC K15, 02 Cav
Engine: 350, 355, Ecotec 2.2
Transmission: 4L60E, TH350, Getrag 5 speed
Axle/Gears: 10 bolt 3.73, 10 bolt 3.08
Please help
thanks
Nothing wrong with being new, everyone starts somewhere. For starters your 85 car has a computer to control the EFI. GM had ECMs in Cadillacs back in 1978ish I believe with TBI injection. The foreign cars had them much earlier than that even. Converting to carb is not a tough job, but it is not practical. There are plenty of things you can do to your TPI without putting a carb on it. Just my Hope this helps
R3500
Aug 24, 2015 09:05 AM
theurge
Aug 21, 2015 12:46 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
