What do you guys think of this...
Old Apr 7, 2006 | 09:14 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
Well, just finnally fixed my main fuel feed line on my 87 bird, Started it up no leaks. idle IS HORRIBLE 3-400 RPM, New fuel filter though i can tell the differance between the throttle responce. anytime i touch the gas runs great with a tiny bit of backfiring through the exhaust with large reving, Im thinking IAC?
or maybe
My cold start injector.. ill check it out tomorow maybe ill just change out to a 88 prom, already ohmed my injectors there all more then 15.6
Lemme know any tests to do, i have a multimeter.. just need t-pins to tap into the sensor and i should have them soon, o and this is a all stock motor
Cleotiz
Jan 6, 2018 08:56 PM
aaron7
Aug 17, 2016 06:02 PM
PestilenceIV
Aug 20, 2015 03:32 PM
Street Lethal
Aug 14, 2015 08:25 PM
Thaney9
Aug 7, 2015 08:25 PM
