Narrowed problem down to Injector but wanted to be sure:
Old Apr 9, 2006 | 05:03 PM
Francis's Avatar
Hi all.
Just wanted to run something by you guy's before I hand over the car to an EFI shop and open my wallet. Now I'm just only starting to get my head around EFI, so that's why I'm telling you everything I have checked and so on.
I have a miss that's been bugging me for a while. I have a old style engine Analyser that I hooked it up to and traced the problem down to Cyl 5. When I isolated that lead from firing it made no difference to the car. After cheeking there is heaps of spark. So I looked to the Injector. If I remove the wiring connector is makes no change to the running quality at all. So I tested it with a Node Light, and it's pulsing fine. That leaves me to assume that only the Injector is faulty.
Now I have never had to remove an injector before so I'm not sure if it's something I should tackle or something I should let an EFI guy do. The only problem there is I ordered a set of near new injectors a few weeks ago to have a spare item, but they wont be here for about 6 weeks (slow shipping) and I don't really want to go spending a heap on these ones if I can avoid it.
Just wondering if anyone has any ideas or advise in what the think the problem might be, if I should look at getting the injector out and so on. Can you try and clean them yourself with Carby cleaner? Is it a big risk getting one out if you have never done it before?
Thanks heaps.
Francis.
Old Apr 9, 2006 | 10:20 PM
DON 88T/A's Avatar
How did this analyser narrow it down to the number 5 cylinder?
What does the # 5 plug look like...any carbon on it?
Check that cylinders compression?
Also you can omh out the injector(15-17 ohms is pretty good)...low ohms mean that it is not opening right.
also put a fuel pressure guage on,prime the fuel line and then turn off and see if the fuel bleeds off quickl(leaking injector)....these are a few things you can do yet...
if they are the original injectors they just may need to be cleaned/serviced..a good place is Rich @ cruisingperforamnce....he does great work on injectors..if you have a new set coming then I would just have them installed if you fully determine it is the injectors. as a side note you can actually remove several/injectors/wires and not notice much in the running of the car(at idle)
Old Apr 17, 2006 | 02:18 AM
Francis's Avatar
Hi mate, sorry for taking so long to get back to you. I ended up getting stuck in to removing the injectors as after you said measuring the ohms the one I thought was the trouble one was open circuit.
I have a big old Engine Analyser. (Scope) It has primary, secondary and power checking tests. Great for older points and early electronic ignition. But still served a purpose with this EFI HEI set up! I did a power check isolating each cylinder from firing and saw that 5 made no change when I stoped it. I placed an in line spark tester and saw a big spark, so guessed that it was not lack of spark.
After the Ohms test I removed it and found an EFI guy had a second hand unit so I bought it and it ran like it has never ran before!
The thing I wanted to run by you and all that care to help, is I found another injector had 28 ohms. I was wondering what is the side effects of high ohms in injectors? Should I change this one as well?
Once I got the car out on the road and warmed up it has developed a little miss. Sort of like cutting in and out on 7 Cylinders. Nothing like removing the EFI harness altogether, but small kicks at idle and constant RPM's.
Secondly I wanted to check something that might sound really basic and silly, but with the injector wirings, do they have to go to a certain injector or can they inter swap between each other? If they are meant to be on a certain injector how would I check they are all right and not crossed over?
Thanks heaps again. Looking foward to hearing from you.
Francis.
Old Apr 17, 2006 | 08:02 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The 28 ohm injector is also bad. All injectors fire at the same time, so which plug goes on which injector is not important.
RBob.
Old Apr 17, 2006 | 12:05 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Don't 4 of them fire once then the other four ? Not all at the same time ?
Old Apr 17, 2006 | 03:35 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Nope. On a TPI they all fire at the same time.
Steve78LT
Feb 24, 2016 12:15 AM
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
