Cam lift????
Old Apr 10, 2006 | 09:37 AM
blazed's Avatar
Car: 1986 IROC-Z
Engine: 5.0L 305ci
Transmission: 700r4, shift kit
Cam lift????
How much cam lift could I go with a stock motor???? I am going to buy heads sometime but dont really have the money right now. Also what else do I need to do when I get the cam installed???
Old Apr 10, 2006 | 05:40 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
.480" is abt the max the 350 tpi (083) heads are good for w/o mods. I believe the 305 heads are similiar.
If its a factory roller cam eng, you can probably re-use the lifters.
If it's a non factory roller cam (flat tappet), you'll need new lifters.
Installing new valve springs (matched to the cam) is a very good idea.
The pushrods may be re-useable. You will have to use a pushrod checker to verify if they are the correct length.
I'd replace the timing chain/gears unless they have been recently replaced.
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
Jorlain
Oct 8, 2015 01:57 AM
abray1
Sep 10, 2015 04:53 PM
IROCtometal
Sep 9, 2015 10:01 AM
