RUNS GOOD COLD BUT NOT HOT
Old Apr 11, 2006 | 09:39 PM
hot 383
Guest
Posts: n/a
I HAVE A 383 WITH TPI A HAD A CHIP MADE BY A PLACE AND PUT IN 30LB INJ.,A 52 MM BBK TB. A 278 DUR. COMP ROLLER CAM . IT RUNS WELL TILL IT HITS 160 TEMP THEN IT STARTS RUNNING BAD AND GOS FROM REAL RICH TO LEAN . THE TIMMING IS RIGHT WHEN COLD I KNOW BUT DONT KONW WHAT IS CHANGING WHEN IT GOS TO HOT LOOP. MY FUEL PRESS. IS AT 40 PSI THATS WHER IT RUNS THE BEST COLD. I PUT A NEW O2 ON IT AND A AIR IDEL MOTOR TO DAY BUT THAT DID NOTHING STILL RUNS BAD WHEN HOT AND WILL DIE AT IDLE.
Old Apr 12, 2006 | 01:42 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Drop the caps . Anyhow , you throwing any codes? I would be talking to the guy who made the chip. It's pretty hard to get it rigth the first time when makeing them.
Old Apr 13, 2006 | 02:22 PM
hot 383
Guest
Posts: n/a
AFTER ALL THE NEW PARTS ,O2, AIR IDLE, TEMP SEN, AND TPS, THE NEW TPS I GOT WAS BAD AND A NOTHER NEW ONE DID THE TRICK. THANKS FOR ALL THE HELP.
justin57
Aug 20, 2015 07:05 PM
jackhammer
Aug 15, 2015 10:04 PM
86Base
Aug 8, 2015 01:34 PM
drathaar907
Aug 6, 2015 04:20 PM
