What is the factory fuel perssure setting of a TPI 305
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
You are supposed to have 42-45 psi (with 43.5 psi being ideal) with the key on, engine off. You may have 36 psi with the engine idling (vacuum is being applied to the regulator, and lowers the fuel pressure), but should not have that with the engine off.
I would suggest you leave your fuel pressure at the stock setting. Raising your fuel pressure will cause you to richen your fuel mixture. The O2 will help pull some out during idle/ part throttle, but not WOT. The engine may feel more responsive, but if you go too far you may be dumping alot of extra fuel into the cylinders. Thats not very beneficial.
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
43psi with engine off and key on, 36-38 with engine idling. that is what my 88 formula was reading when I was checking it.
Former Sponsor
Car: 1992 Camaro RS
Originally Posted by kickasscamaro
36 psi for stock 305 without any vacuum
colton_carlson
Mar 8, 2019 12:21 PM
Fast355
Dec 2, 2016 06:33 PM
drathaar907
Aug 10, 2015 07:44 AM
