Dropping Fuel Pressure
Old Apr 13, 2006 | 10:14 AM
AussieGTA's Avatar
Car: Trans Am GTA
Engine: 350TPI
Transmission: T700R4
Axle/Gears: 3.45
A little while ago before I put the car back into storage I had a few test drives and monitored a few systems.
One of those systems was the fuel system, more to the point fuel pressure. I noticed from a standing start and going to WOT the fuel pressure would gradually reduce from 48psi to about 30psi by the time I was at the 1/4 mile mark.
Both intank and external filters where brand new.
Any comments or thoughts, is this normal?
Is the pressure measured the pressure going to the injectors, or the pressure in the return line?
Thanks guys.
Old Apr 13, 2006 | 11:33 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
BTDT. Your fuel pump is dying and needs to be replaced.
Old Apr 14, 2006 | 08:22 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
if you are going with stock PUT IN A GM PUMP!!!!
It is worth the extra 10-20 bucks
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
