Help with what distributor will work in 86 5L TPI Trans Am.
Old Apr 12, 2006 | 01:39 AM
Francis's Avatar
Hi all.
Just after some help with getting a new distributor for my 86 5L TPI Trans Am.
Firstly I'm located in Australia, so finding a local shop here that knows what part number is best just wont happen. Trans Am's are an exotic here.
Problem is last owner has installed a Procomp Electronics Distributor. PN: PC - 10001_ Chev Late Model HEI. PD 1-12. website PROCOMP ELECTRONICS
This is a late model HEI style that has a separate coil (not in the Cap).
Aside that I have been told so many bad things about these units, when I pulled a lead off the cap the other day the whole rod going in to the housing cam up with it. I have chased the Australian agent for a replacement cap and while I'm at it Rotor, but no one seems to know anything about the 10000 series only the 6000 & 7000.
So I'm going to start looking at either finding a good original unit to fit back in or if anyone can offer and information as to what other units are worth chasing, Such as MSD or Mallory? If someone knows a model number that is a direct replacement unit I can use and also recommend a model number for a quality coil that would be soooo appreciated.
Also if anyone knows a good place to order one that will ship worldwide that would help heaps and save me dealing with people that have no idea over here.
Thanks heaps in advance.
Francis.
Old Apr 12, 2006 | 06:23 AM
super_kev's Avatar
Car: '85 TA
Engine: Aluminum Fuelie
Transmission: Mother of All Manuals
You'd be better off posting this in the TPI section. I'll notify a moderator to move this over there.
If nobody is able to help you, I can grab one from Summit Racing, Napa, etc. and possibly ship it to you.
Old Apr 12, 2006 | 08:15 AM
thefightback's Avatar
Car: 86 Z28
Engine: '90 350 TPI
Transmission: T700
firstly, hello from Perth
try usgmserviceparts.com if you havent already. theyre in sydney and have a vast knowledge of our cars. always happy to help with info and EXCELLENT service. they will also be able to order anything you want from where ever you want to save you the hassles.
also try ask on camaro-firebird.org if you need some info - its an aussie forum and the guys there are a wealth of knowledge.
Old Apr 12, 2006 | 08:22 AM
Duts87ss's Avatar
Car: 1987 Monte Carlo SS
Engine: HSR 383 AFR180/268XFI EBL
Transmission: 200-4R, Edge 2800 L/U
Axle/Gears: 7.5/3.73/PowerTrax No-Slip
In the US, this type of distributor was used in GM V8s from '87-'97or'98. I would think you could find a replacement cap and rotor (even plug wires) for a V8 Holden vehicle of the same era.
Old Apr 12, 2006 | 09:57 AM
blackroc68's Avatar
this is the tpi section
Pac J
May 17, 2020 10:44 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
FormulasOnly
Jul 23, 2018 08:47 AM
mfp189
Sep 27, 2015 09:25 AM
