floating wire
Old Apr 12, 2006 | 04:16 PM
chevy boi's Avatar
Car: 1989 i roc-z28
Engine: 350 tpi l98
floating wire
he i just got done replacing my injectors and i noticed that a wire is just hanging there it looks like it was ripped off it was inbetween #4 and #6 cylinder and i have no idea were it gose any help whould be greatfull
Old Apr 12, 2006 | 04:38 PM
mean57's Avatar
Car: 87 gta
there should be a temp sensor mounted in head near there. also could be from knock sensor it's on that same side but mounted in engine block. a picture would help but i believe those are the only one wire sensors on that side in that area.
Old Apr 12, 2006 | 04:52 PM
chevy boi's Avatar
Car: 1989 i roc-z28
Engine: 350 tpi l98
well i kno its not the knock sensor because i seen that was in when it was on the life and the temp sensor whould explain why my fans are not turning on anymore so should i just get a new connector? also i rember reading on here that i can hook up a switch to that wire and be able to run the fans buy switch should i just do that instead
Old Apr 12, 2006 | 05:05 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Yup, sounds like fan switch. sure, you can wire up a manual switch, but I would still reconnect it as well. that way when you flip it off it will go back to stock and not overheat.
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Irocohio
Aug 12, 2015 08:03 AM
