87 Camaro cutting out/dying when first started
Old Apr 15, 2006 | 08:39 PM
jjg's Avatar
jjg
Hey guys I have an 87 Camaro Iroc z-28 with a 305 TPI, I have recently replaced the 02 sensor, the egr valve, plugs wires rotor an distributor cap and vacuum hoses.. Seems when I first start it up it wants to cut out and die so I hold the gas down until it warms up enough to idle on its own. I put the car in gear RPM's drop to 750. When in park i try to stomp on the gas and it hesitates and cuts out. When i am driving it really seems to bog down and doesn't have any power. Is this a timing issue? If you guys could point me in the right direction I would appreciate it
thanks
John
Old Apr 16, 2006 | 09:40 AM
redrummer's Avatar
Car: '88 Trans Am GTA
Engine: 5.7L L98
Axle/Gears: 3.27 Aussie 9 Bolt
Vacuum leak, sounds like. Go back over everything. Everywhere there's a vacuum connection, spray it with carb cleaner with the motor running.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Caspar
Jun 19, 2016 11:19 PM
92camaroJoe
Aug 13, 2015 06:07 AM
