Ford Racing Injectors
Old Apr 26, 2006 | 10:14 PM
kevlar8in's Avatar
Can anyone fill me in?
What is the difference between the Ford Racing injector kit that Summitracing has for sale as FMS-M-9593-F302 for $275, and the ones for sale at Jegs as 397-M-9593-F302 for $204 - other than the price difference of course =). Time for an upgrade.
Many thanks in advance,
Old Apr 28, 2006 | 11:14 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Ford Racing injectors are the best thing Ford has ever made. Lots of GM guys use them. They will attach exactly the same as stock GM injectors. There is a "slight" height difference though. Some members file down the fuel rail attach points on the lower intake to lower the fuel rail slightly for better injector sealing.
If you want to stay with GM injectors my buddy (neighbor) has a almost brand new set of factory LS1 fuel injectors for sale from his 2004 GTO. They have 3500 miles on them and will fit TPI applications also. He wants $100 for them. Here's my link to the classified section with the injectors.
FYI....late model LS1 injectors are rated at 28 pounds.
https://www.thirdgen.org/forums/part...tors-28-a.html
Old Apr 28, 2006 | 12:45 PM
ResurrectingZ's Avatar
Car: 1987 IROC 1991 RS
Engine: 5.7 TPI 5.0 TBI
Transmission: T-5 , 700R4
Axle/Gears: 2.73 twice
The problem with LS1 injectors is they are much shorter than the stock fuel injectors, there is also less resistance on the injectors, and good luck on the fuel injector clips. Tried to use these for my miniram, and I am not comfortable enough to attempt to use them. I like the 4 bar spray though. Don't know if LS1 injector clips would fit, cant get them anywhere around here.
Old Apr 28, 2006 | 01:14 PM
Guest
Guest
Posts: n/a
I think they have a 'matched' set and non-matched that are different prices. Maybe thats what it is, but I cant say for sure.
Old Apr 28, 2006 | 01:29 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I run the LS1's on my 383 and the Ford Motorsport ones on the 355. Happy with both.
Old Apr 28, 2006 | 01:34 PM
kevlar8in's Avatar
I bought the set from Jegs yesterday, seemed like a good deal. They have the same Ford part# for the most part - hoping the are the same red-tops I keep reading about! I will file down the mounting surface so the rail sits a few mm's lower, and I may even replace the o-rings if the ford ones look to thin. I have the fuel rail apart too, so I'll change those o-rings as well.
Drone358
Dec 10, 2015 08:16 PM
BAMiller
Sep 14, 2015 06:38 PM
Amillionoh7
Sep 5, 2015 11:44 PM
SG91camaro
Sep 5, 2015 10:27 PM
Strick1
Sep 4, 2015 07:11 AM
