Should I not smell any fuel, in FPR vacuum hose?
Old Apr 26, 2006 | 10:44 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
I've had some conflicting facts/opinions/what-have-you, on the FPR being a possible culprit in my 7 week old engine rebuild saga.
** Cliffnotes- The motor runs, just not well and extremely rich. I have done numerous tests and still the motor doesn't run right. I have set timing 2 times and currently undertaking a 3rd time right now. But I'm on a break at the moment.
Back to the topic, people have told me to check my FPR and smell the vacuum line. If I smell gas it is bad. I do smell gas. I also heard that if it's wet it's bad. It is not wet. I unhooked the vacuum hose it while the motor was running and no gas came out. Not even a drop.
So, if does that mean the FPR is shot if I smell a trace of fuel? I do, or does it w/o a shadow of a doubt have to be wet with fuel and splurt out into the vacuum line or out if unhooked with the motor running?
Old Apr 26, 2006 | 10:50 PM
89TA383M5's Avatar
Car: 89 TA
Engine: 413 TPI
Transmission: TKO 600
I would say that for the regulator to be bad it would have to be leaking fuel
1992 Trans Am
May 10, 2023 07:19 PM
dyeager535
Aug 28, 2015 08:10 AM
86IROC112
Aug 17, 2015 02:00 PM
wayshegoes
Aug 17, 2015 12:00 PM
