TPS: Good or Bad???
Old Apr 27, 2006 | 06:52 PM
4rcFed's Avatar
Car: 1989 IROC-Z
Axle/Gears: Just About STOCK
TPS: Good or Bad???
Ok, been having a vibration with my car. It will have a vibration only between 1,500rpm and 1,600 rpm. Above and below that is ok - - - car is in park.
Just to check, I thought there may be a dead spot in the TPS. Hooked up a VOM tonight and it read 0.50V and 4.30V @ WOT. While opening the throttle very slowly, it did have a spot where the volt meter wouldn't read, but that was at roughly 4.00V - 4.15V.
If I am trying to compare a vibraton at such a low rpm, I should see a dead spot closer to the 0.5V region, correct???
Second question - since there is a dead spot existing, should this be replaced anyways?
I did try to adjust it to get 5.00V @ WOT, but then I had 0.93V at the closed throttle position. So I readjusted it to get 0.54V closed, and 4.50V @ WOT.
Please let me know your thoughts! I know many of you have fought this!!
Old Apr 27, 2006 | 11:36 PM
puffcat's Avatar
Car: 1988 Iroc-Z
Engine: 305 v8 tpi
Transmission: manual
Axle/Gears: posi
Is it a vibration at just park or while driving? I had a similair problem while driving from stop to 2nd it seemed. Check your tranny mounts if that's the problem. Mine were looses, and broken. I tightened them up and vibration gone... except when I'm at a stop.
Old Apr 28, 2006 | 05:39 AM
4rcFed's Avatar
Car: 1989 IROC-Z
Well there is a vibration in the steering wheel while driving, but I was leaning towards other things for that. So to try and isolate things, I checked the car while sitting still, in the driveway. And the car will vibrate while sitting in park, revved to 1,500rpm.
Old May 1, 2006 | 01:55 PM
4rcFed's Avatar
Car: 1989 IROC-Z
Noone has any ideas????
86IROC112
Apr 9, 2016 10:20 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
db057
Aug 22, 2015 08:17 PM
InfinityShade
Aug 22, 2015 08:00 PM
