EGR Temp sensor/switch
Old Apr 28, 2006 | 09:53 PM
Scotty27's Avatar
Car: 1989 IROC
Transmission: t5, wanna be a t56 when I grow up!
Axle/Gears: Whatever stays bolted on behind me!
Hey all,
Pulled plenum off to look at egr sys, (shows code 32 after highway) and found that the egr temp switch wire was broken.. ie not attached. Would this alone cause code 32 to appear, or is it likely that the problem is elsewhere as well? Obviously that part needs to get replaced.
Scott
Old Apr 28, 2006 | 10:45 PM
r_wells1's Avatar
Car: 89 IROC
Engine: vortec head/ZZ4 cam/TPIed 350+.040
Axle/Gears: 3:27
Its a good start. The EGR switch is grounded when the hot exhaust gas flows through the EGR. The ECM looks for this ground after it activates the EGR. If the ground does not occur, code 32 is set in the computor. A broken wire would prevent the ECM from seeing the ground.
Another thing to watch out for is during emission testing. I've seen it where the EGR fails to work and emissions test fail, yet a code 32 does not come on. The wire breaks off and grounds itself against the fuel rail or manifold fooling the ECM to think everything is working.
Old Apr 28, 2006 | 11:53 PM
Elephantismo's Avatar
Car: 91 z-28
Engine: 350 F code
Transmission: 5spd
This is all for 90 and up only i belive non MAF TPI cars.
If you are talking about the temperature sensor in the underside of your plenum, ya that prolly would do it all on its own. The ocmputer uses that sensor, the water temp that comes int he trottle body and the MAP sensor to control fuel mixture. If that sensor is out it can hamper along but if it constantly reads too high or too low from the water temp then it will prolly throw a code.
Old Apr 29, 2006 | 12:23 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Originally Posted by Elephantismo
This is all for 90 and up only i belive non MAF TPI cars...
My 88 TPI has an EGR temp/switch.
Old Apr 29, 2006 | 05:52 AM
Vader's Avatar
So does my '86:
Old Apr 29, 2006 | 08:58 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
90-92 cars didn't use the temp switch. It's listed as 85-89. I researsched this for my swap as the intake I'm using is from an 89 and my ecm and harness are from a 91 and the car is a 90.
Old Apr 29, 2006 | 08:46 PM
Car: 91 z-28
Engine: 350 F code
Transmission: 5spd
90-92 models switcheed from Mass AIr Flow to Mass Air Proportioning sensors (speed density). The speed density system does not have a sensor on the egr valve itself. It does have a sensor that reads from INSIDE the upper intake manifold. It is used in unison with the MAP and coolant temp to regulate fuel mixture. Sounds wierd... but true.
sheachopper
Jul 31, 2019 11:27 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
