pressurized?
Old Apr 29, 2006 | 05:07 PM
start'er up's Avatar
Car: 1988 pontiac trans am
pressurized?
Hi, im pretty new to the forum, but i have an 88 trans am, with the 5.0L v8, 305 tuned port injection, and i blew a head gasket. So i know, or am pretty posistive that its a pressurized fuel system, so what is the proper way to go about takin off the multi port system, and any other advice about this process would be apreciated, because i usually dont deal to much with the pressurized systems, thanks a lot
JRance
Old Apr 29, 2006 | 05:19 PM
Vader's Avatar
Remove the cap from the fuel pressure test fitting on the right fuel rail. Depress the center pin on the core of the test valve (just like a tire inflator valve) to bleed fuel pressure. Make sure the engine is cooled and the area is well ventiallated, since some liquid fuel may run from the port. Standard precautions for dealing with liquid and vaporized gasoline will be required, of course.
Old Apr 29, 2006 | 05:30 PM
MattODoom's Avatar
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
Originally Posted by start'er up
with the 5.0L v5, 305 tuned port injection
That's a rare option.
Old Apr 29, 2006 | 05:32 PM
v8, haha, my bad, and thanks a lot, now once the pressure is releaved, it is save to take off, correct, and does this pressure will rebuild itself ? thanks
JRance
Old Apr 29, 2006 | 07:20 PM
mbood82's Avatar
Once the fuel rail is de-pressurized you are clear to start removing the fuel rail and such. Be careful of the o-rings on the injectors, or better yet have a spare set to replace them anyways.
The pressure will rebuild itself when the fuel pump is next energized. Basically, once you are done replacing the headgasket, turn the key to "on", let the pump cycle, turn it off again and then try starting the car. It should start up just fine for you then.
db057
Jan 10, 2020 08:55 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Stryker412
Sep 20, 2015 06:59 PM
TBRays98
Sep 6, 2015 05:05 PM
