tpi and plenum black sut inside???
Old May 1, 2006 | 08:40 AM
WILL85IROC's Avatar
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
i took out my intake, plenum and runners yesterday and they have a thin layer of black sut build u inside, is this normal??? the engine is getting rebuild and i want to poss re-use these parts, can i just clean em??? and what is the black stuff???
Old May 1, 2006 | 09:38 AM
Guest
Guest
Posts: n/a
Normal. Its a combination of things from fuel vapors to oil vapors to exhaust vapors coating the surface of everything from the TB back.
Old May 1, 2006 | 09:40 AM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
ok, thanks, i ll ignore it....
Old May 1, 2006 | 09:50 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
An oil catch can will prevent the dirty intake.
Old May 1, 2006 | 09:55 AM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
whats that and where can i get one???
Old May 2, 2006 | 01:39 AM
Engine: 4.0L
A catch can is a device to capture excess oil from the PCV system before it makes it to the intake. It is very common with the 4th gen F and Y bodies with LS1 engines because they have a great deal of bypass oil picked up in the PCV system.
I have yet to see one used on a 3rd gen TPI but I am sure it's possible. Here's a link to one persons install of a nice, billet catch can on a new GTO. It's give you a general idea but isn't the only catch can available by far. Some people use an air compressor ail/oil seperator for a cheap but effective catch can. All cans capture oil so they must be able to be drained fro time to time.
http://www.redgto.com/KB/article.aspx?id=10001
Old May 2, 2006 | 09:25 AM
Vader's Avatar
The same thing happens inside LT1 intakes, carbureted intakes, 4- and 6-cylinder MPFI intakes, CPI/Vortec intakes, CFI intakes, and probably LS1 intakes - blowby or not. You can clean it out, but in a few months of use it will be back. Unless it is completely covering an EGR port, vacuum port, or the MAT sensor, it probably isn't harming a thing.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
MantyZ28
16
Dec 21, 2015 11:02 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Sanjay
Aug 12, 2015 03:41 PM
