Fuel Pump Pressure Question need help.
Old May 2, 2006 | 07:33 AM
seiplentz's Avatar
Car: 85 Z28
Engine: GMPP 350 HSR
Axle/Gears: 4th gen 3.42 Posi LS1
I am having a bit of a fuel pressure problem and I am looking for the right direction to head to find the problem.
First- Presure at the rail is 32psi with an afpr that was origanally set at 45psi. It also does not hold pressure I have new injectors all ohm out around 15.9. the only one that is not new is the cold start possibly leaky.
Second- Put a gauge right on the main feed to the fuel rail pump primed to 30psi and dropped down to 0 after about 5-10 seconds.
Should the pump prime to full pressure when not attached to the rail and hold. If so what should the pressure be.
The car does run and pressure drops to like 22psi when you hit the throttle which is deffinatly not enough fuel for my setup. I get hesitation when I first hit the gas.
Pretty much I just what eliminate if it is the pump or not.
Old May 2, 2006 | 07:42 AM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Sounds like pump or clogged filter. But, if the pump is pumping through a clogged filter, it will quickly wear out.
Old May 2, 2006 | 11:49 AM
seiplentz's Avatar
Car: 85 Z28
I origanally thought that too and already replaced the fuel filter.
Thanks for the help though.
92camaroJoe
Jul 29, 2023 07:57 PM
jklein337
Sep 19, 2018 06:23 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
