gas pump relay?
Old May 4, 2006 | 07:00 PM
2badcams's Avatar
Car: a 91 rs convertible and a Iroc z convertible
Engine: 305 tbi, and 350 tpi
gas pump relay?
hope this question fits the thread, but wasnt sure where to put it! well im having problems getting gas to the engine, so im going to try replacing the relay. i bought it at autozone and when i came back home i popped open the hood and noticed that all three relays look the same? which one is the actual fuel pump relay? thanks!
Old May 5, 2006 | 01:25 AM
85IrocZ-28's Avatar
Car: 1985 Iroc Z-28
On my 85 TPI, it was the one on the far right. If the fuel pump is working at all, here is how you test it.
Turn the key on...you hear the fuel pump. Disconnect them one at a time until you don't hear the fuel pump kick on, that is your relay.
Old May 5, 2006 | 04:10 PM
2badcams's Avatar
THANKS!!! hopefully now i can get it started, if not ill check for something else
Old May 5, 2006 | 06:33 PM
2badcams's Avatar
i replaced the relay, and also tried to "jump" the wires to see if the pump works, but i get nothing. i guess ill try replacing the opsu, but if that fails, i noticed someone talkin about replacing the sending unit? if so what and where is that located?
one more question, i believe their is 3 cables going to the pump, 1.black 2. purple 3. grey, well i checked the cables for current using a tester, and only the grey cable turns on when the key is in on position. i know the black is ground, but what about the purple one? should this one have current to?
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
Dialed_In
Aug 20, 2015 01:45 PM
Bryan F
Aug 18, 2015 02:28 PM
Kaweh
Aug 9, 2015 02:54 PM
