Stock LT1 injectors
Old May 7, 2006 | 06:39 PM
TundPortZ's Avatar
Stock LT1 injectors
hey guys my 86 IROC 305 TPI (auto) has the following mods and i was wondering if stock lt1 injectors would do well on it. The way it sits it's usually evenish with stockish lt1s
-Crane PowerMax Cam 264/274 ADV, .423/.446 @ valve
-Edelbrock T.E.S. 1 5/8 prim. Headers
-Hooker Aero Chamber cat-back
-Ported plenum, MAF, gutted airbox,filters, airfoil etc...
-all accel ign. stuff
-removed a/c compressor
-may be other stuff, dont quite remember
planning on
-AFPR
-possibly 1.6 rollers
-needs new TPS, timing...
Old May 8, 2006 | 07:33 AM
1993formulav8's Avatar
Car: Camaro, Firebird
I would think the 24lb injectors are a bit much for a 305 with the little bit of mods that you have. Im running a 350 with a higher lift cam, edelbrock performer rpm heads and 1.52 roller rockers and they seem a bit much unless I run the fuel pressure down to 35 psi.
Old May 8, 2006 | 12:49 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
I am running lt1 24lb injectors on my 305tpi.
It is rich and I lost 2-3 mpg but the power level and driveablity did not change.
I only put them on b/c I want to run a 125 n2o shot this year.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
gta90
Sep 15, 2015 04:00 PM
sreZ28
Aug 14, 2015 07:48 PM
Thirim
Aug 9, 2015 06:19 PM
