code 43
Old Apr 24, 2006 | 12:05 PM
jstoll's Avatar
Car: 91 Formula
code 43
What does a code 43 mean. I am haveing high idle problems. I did check my tps it reads 2.5 at idle. iac is new. Someone told me 43 means I have it timed incorrectly. Thanks Jason
Old Apr 24, 2006 | 12:41 PM
Shagwell's Avatar
Car: projects.......
TPS 2.5 @ idle???? should be .54
Old Apr 24, 2006 | 12:55 PM
jstoll's Avatar
Car: 91 Formula
Ya I know I think its a litle high. I was just wondering it that was why I have the 43 code. Also I am getting shocked every time I touch the wire above the coil. I put a new wire on and same thing. That gets pretty annoying. I don't think you should get a shock from touching a good wire. Is there something wrong with my coil??
Old Apr 24, 2006 | 01:16 PM
92 Formula's Avatar
From: Avatar: My 34' 1989 Scarab III w/ twin 454's (502's Started!)
Car: 1989 Wellcraft Scarab III
Engine: Twin 454's
Axle/Gears: Twin Mercruiser Bravo I's
I've never had to deal with a code 43 personally, but if IIRC code 43 is a poor electrical connection/short. ECM/knock sensor/ESC module. Double check as I may not remember correctly...
Old May 8, 2006 | 01:01 PM
jstoll's Avatar
Car: 91 Formula
Found the problem. I had to laugh at myself for a while about this one. I have the secondary fan and knock connectors switched around. I figured it out after reading other threads. Someone said if you ground your fan conn. the fan should turn on with ignition on. It did. Also I found that the fan conn. reads 12v and the knock conn. reads about 5v.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
