what heads for 88 350?
Old May 9, 2006 | 10:20 AM
Don 79 TA's Avatar
Car: Hers: 88 Formula 350
Engine: TPI
Axle/Gears: 10 bolt Posi
tossing around an idea..
since i have broken exhaust bolts in the heads now, and it really needs valve guides, i was thinking about replacing them with something that will bolt right on, and allow for some future growth. i want all the accessories to bolt on as is, and use the stock TPI setup the way it is.
it's her 88 formula 350 with 85k, runs good, except now i have the broken exhaust manifold bolts to deal with. snapped off flush with to the head. rear bolt too
what sice cc chambers should i look at?
what is the stock head cc? and valve size?
world had a street torquer head at 76cc for 87up
Jegs has them for $400 complete. would they work?
i'd prefer aluminum if possible, to save weight and add compression.
955-042770-1
JEGS High Performance - World Products SB-Chevy S/R Torquer Heads
currently the car has basic bolt-ons, right now using exhaust manifolds
Old May 9, 2006 | 11:22 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
The stock B2L heads have 64 cc chambers. I forget the port size.
Depends on how much you want to spend really.
Old May 9, 2006 | 05:00 PM
Don 79 TA's Avatar
Engine: TPI
i think i am going to try putting the exhaust back together without that bolt
and see what happens
maybe as a fall/winter project i'll do a head swap or change
i have a bolt missing on the rear drivers side too, second one towards the firewall
i'll just wirewheel the exhaust manifold down and put the gasket on
1404 felpro
i think i might look at getting some l98 vette heads in the future or some newer aluminum ones to save weight.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
NinjaNife
Aug 23, 2015 11:49 AM
NWAsonoma
Aug 18, 2015 05:45 PM
