TPS SENSOR
Old May 10, 2006 | 08:36 PM
graphicideas1's Avatar
TPS SENSOR
when i check my tps sensor with tunerpro it only shows 4.5 volts wide open, & .50 at idle- is this correct? if i take the sensor out & test i can get it to go up to 4.92 volts but the throttle lever(fully open) does not push it far enough to get it to that point
Old May 11, 2006 | 07:37 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
You are good to go... I set my TPS voltage at 0.62V at idle, at WOT it reads about 4.2V... I have an '87 car, so my TPS is adjustable.
But, your values are OK, unless you notice some TPS related problem.
Old May 12, 2006 | 08:40 PM
I
I always thought that it need to read 5 volts at WOT - 4.2 is far off
Last edited by graphicideas1; May 12, 2006 at 08:41 PM. Reason: Automerged Doublepost
Old May 12, 2006 | 09:54 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
[QUOTE=graphicideas1]I
The ECM will know there's a problem and set a code if the voltage goes below the minimum, or above the maximum. So it needs at least a 1/2v above and below the TPS total span to be able to determine when the TPS is out of range.
db057
Jan 10, 2020 08:55 PM
92firebirdguy
Sep 1, 2016 07:53 AM
bbsr72
Apr 2, 2016 09:12 AM
Fred SS
Oct 12, 2015 11:27 AM
BWilcox
Sep 20, 2015 12:19 PM
