timing question
Old May 12, 2006 | 08:31 PM
87irocz28_383's Avatar
Car: 87 iroc z28
Transmission: 700-r4
Axle/Gears: 9-bolt, 3.27 gears
timing question
ok i have an 87 iroc z28 wit the 350 tpi and i want to advance the timing but i just want to make sure the injectors timing doesnt run off the distributor timing ..and also wut would b the best advance if it do able
Old May 12, 2006 | 10:16 PM
Vader's Avatar
The ECM uses the same signal from the distributor to operate the injectors that the distributor does to time spark. It doesn't matter for the injectors, since they are batch fired. Altering the distributor advance will not affect fuel delivery.
Old May 12, 2006 | 10:19 PM
Car: 87 iroc z28
thank you very much for the response it was exactly wut i was lookin for
Old May 12, 2006 | 10:30 PM
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
Axle/Gears: Limited 9 bolt, 3.45
what fuel are you running?
6* stock
8* is usually good for 87..
12-15* for 93...
make sure you unplug the white and brown wire from the pick up..
Old May 12, 2006 | 10:34 PM
Car: 87 iroc z28
fuel is 91 octane most of the time and 94 on special ocassions..lol or when ever im around a sunoco everywhere esle around me only has 91 so i was thinking around 10*??
Old May 12, 2006 | 10:37 PM
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
start at 8* and advance it 2* until it pings....when it pings back it off 2*
Old May 12, 2006 | 10:38 PM
Car: 87 iroc z28
aiight thank you very much
MustangBeater20
Oct 29, 2022 09:20 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
