swaped my engine and now im smokkin
Old May 11, 2006 | 04:23 PM
ALONZO_MANUEL's Avatar
Car: 1986 IROC-Z
I HAD A 86 305 TPI I BLEW IT SO I PUT IN A 91 305TPI AND NOW ITS SMOKKIN BLACK SMOKE OUT THE TAIL PIPE A MECHANIC TOLD ME IT COULD BE THE ECU SO I CALLED THE DEALERSHIP AND THEY TOLD ME ITS TWO DIFFERENT ECU'S BEING THAT ITS TWO DIFFERENT YEARS BUT FOR THE 91 305 THERES ABOUT 12 DIFFERENT DIFFERENT SELECTIONS HOW DO I FIND OUT WHICH IS BEST FOR ME?
Old May 11, 2006 | 04:51 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Provided that you used all the stock sensors and wiring from the 86 the ecu should not have a problem controlling the motor. By 91 GM had changed the engine managment system to speed density as opposed to maf sensor but that was only the electronics, the motors themselves are not all that different from each other. The 91 has a roller cam and different heads.
Did you do the swap yourself, or did the mechanic do it?
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
