Best gears for LTR with ZZ-9 Camshaft
I need a little help in picking out some gears for my application. I am running a stock intake but hope to upgrade to the TPIS big mouth intake and runners in the next year or so. Currently the ZZ-9 cam runs pretty good up top. But in the lower end of the rorque curve it bogs a fair bit. My buddy suggested I put in a shorter gear set (like maybe 4.11 or 3.73). This car will never go to the track and is more of a streeter than anything.
Will these gears be alright or will I be greatly disappointed. I currently have 2.73 in there and I think this is why the bog might be occuring.
You won't need a lot of gear with a LTR intake and that cam. I'd go with 3.23 or 3.42 if you have the 10 bolt or 3.27 or 3.45 if you have the 9 bolt. ZZ9 is not that wild so you should be able to tune out any bogging on the low end.
So you figure 3.73 gears would be terrible with my setup?? The reason I am asking is because I think I can get my hands on a set for free, but I don't want to install them if I will be unhappy with them. Thanks for the input!
3.73 aren't terrible and you can't argue with the price. They'd be great for in-town driving with the right tires and suspension set-up. It's just that a LTR TPI with stock heads is going to make peak power below 5000 RPM so you'll run out of breath on the top end in a 1/4 mile race. It will pull great down low if you can hook it up.
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I'm running the combination you are talking about except I have higher flowing heads and intake system to take advantage. I think Mark has pretty well nailed it for your situation. For a street machine that never sees the track I would opt for the 3.2x gears depending on what rear end you have.
84 TA NV
Sep 6, 2015 08:02 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
