Easy way to get a temp gauge on non-3rd gen TPI?
Old May 13, 2006 | 12:17 PM
dperk's Avatar
Hi, I have a SD TPI setup in my Jeep CJ7 and I'm trying to find a way to get a temp guage (preferrably electrical) hooked up. I have an earlier manifold with the 2 temp senders, and I'm only using the CTS, not the cold start. Can I plug some type of gauge into the other GM temp sender? If so, can I buy an aftermarket one from summit or something?
or, can I take some output off the computer (7730) for a temp readout?
Thanks for any help!
-darren
Old May 13, 2006 | 03:24 PM
battman's Avatar
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
The two temp sensors your talking about go to the ecm only. you should connect the temp gauge to the sending unit on the drivers side head. on thirdgens the instrument cluster guage is run off the sending unit on the head not the ecm.
Old May 13, 2006 | 03:42 PM
dperk's Avatar
OK, thanks for the reply! I'll have to track this sender down. My motor was from an 86 corvette (L98) with steel heads. Too bad there isn't a fancy device that can interpret the signal from the GM sensors and relay it to an electronic gauge... Something smaller than my laptop
Reddeath210
Oct 6, 2015 08:20 AM
R3500
Aug 17, 2015 12:16 PM
BurlyChev
Aug 16, 2015 09:08 PM
bamaboy0323
Aug 15, 2015 07:20 AM
Sanjay
Aug 12, 2015 03:41 PM
