Ford Mod Motor injectors... will they work???
Old May 14, 2006 | 02:33 PM
LVZ2881's Avatar
Car: 1988 IROC
Transmission: 5 speed
Axle/Gears: 3.08 Posi 10 Bolt w/ aluminum drums
I dont know if Mod motor injectors are the same as Fox body and 3rd gen injectors, but I would have to assume that they are.
I need new injectors for my IROC, and a friend has some 19#'s out of a 98 GT with only 20,000 on them for FREE!!!
any1 know if there is a difference that will prevent me from using them???
Old May 16, 2006 | 03:58 PM
Ant's Avatar
Ant
Car: 1989 Iroc-z 1994 Z28 LT1
Engine: 5.7 Liter L98 Tuned Port Injection 5.7 LT1
Transmission: 700R4 and 4L60E
Slap them on, connecter and everything is the same they are just a hair shorter than ours
Old May 16, 2006 | 08:54 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Ford makes two kinds of injectors. On pg 115 of their catalog are EV1 and EV6 injectors. They appear to be the nearly the same length, but have different plugs. You want the EV1 style injectors, your fuel injector plug will plug directly into the EV1 Ford injectors. I am using the EV1 24#/hr injectors running at 52psi on my stroker motor.
The ford injectors are 2mm shorter than Bosch injectors. A short time ago, I posted the length differences.
I met to add that I believe that the 4.6liter modular motors are using the EV6 injectors. You want the injectors from the earlier 5.0liter engines, these are the EV1 injectors.
Old May 16, 2006 | 09:30 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Also low ohm and high ohm injectors. You need the high ohm version. Around 15 ohms of resistance.
Frozer!!!
Jan 19, 2024 04:55 PM
jhawkeye
May 25, 2022 06:33 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
matthew911
Aug 12, 2015 09:38 AM
mustangman65_79
Aug 8, 2015 01:18 AM
