Should the Stealth Ram Fuel Rails Keep Pressure when the car is off???
Old May 14, 2006 | 10:44 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
Like the title asks.
Tonight I got the fuel pump to finally prime (man I wish I didn't cut off my fuel pump realy thinking it was a fan relay...) and at first it kept pressure at about 22 PSI until I primed it a couple more times to completly fill the lines and bleed the air. Now I don't hear anymore air bleeding from the AFPR (stock one that comes with the HSR fuel rails) but after the fuel pump is done priming the fuel pressure goes back down to zero.
At first it went quickly back down and now it very slowly dropping...
anyone?
Old May 14, 2006 | 10:51 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
replied to your other thread, and yes it should hold the pressure.
9192camaro
16
Feb 3, 2019 12:21 AM
kyleb24
Aug 15, 2015 08:24 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
L98GTA87
Aug 11, 2015 06:55 PM
92projectcamaro
Aug 6, 2015 01:20 PM
