MAF simulator
Old May 16, 2006 | 11:28 AM
bigmaciroc's Avatar
MAF simulator
does anyone know if it is posable to make of buy a MAF simulator?
Old May 16, 2006 | 12:52 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Yes, just pull the Maf sensor plug, and let the ECM go into default mode.
Old May 16, 2006 | 07:24 PM
iroctj's Avatar
Car: 86 IROC-Z
Engine: 385 TPI
Transmission: 700-R4
Axle/Gears: 9Bolt 345'S
plulling the plug will make your car run horrible(previous gm master tech 4 11years). I have been looking for a way to get more air in my tpi(not to be confused by tb to the heads but form the air filter to the tb). This is what i did just this weekend! I took a 90deg. ruber snout off a lt1 car, connected my maf(screens and fins allready removed) ,then attached a lt1 style cold air induction 4in pipe, folled by a K&N cone filter below where the charcoal canister used to be, and cut a hole so it sits in front of the front drivers tire. This picked up 26 REAL WHEEL HP!
Old May 16, 2006 | 07:31 PM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
How do you know it picked up 26?
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
racereese
Oct 3, 2015 03:46 PM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
