Remove MAF/ Speed den. sensor?
Old May 19, 2006 | 10:05 PM
Zrunner90's Avatar
Car: 1990 Camaro RS Ttops
Engine: 89 IROC 305 TPI
Transmission: M5
Axle/Gears: 3.23 limited slip
I see alot of TPI camaros that dont have the extra intake tube for the mass air or speed density sensors. whats been modded to be able to run w/o it, or has it just been moved somewhere esle in the intake?
Old May 20, 2006 | 08:37 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
The MAF is in the intake ducting, thereis nothing in there on speed density set-ups.
Old May 20, 2006 | 09:04 AM
Zrunner90's Avatar
Transmission: M5
I knew the MAF sensor was in the ducting, but i see alot of tpi motors at races that dont have the ducting that the sensor sits in....alot of em just have a cone filter right on the throttle body. I was wanting to do a setup similar to that but i didnt know if i had to do any special tuning or other mods to be able to.
Old May 20, 2006 | 02:04 PM
lakeffect2's Avatar
Car: 1993 Caprice wagon "Shammoo"
Engine: tpi'd 406, with P4 ebl EBL 730 ECM
Transmission: custom "4L65" swap.
Axle/Gears: 3.42:1 with posi
I would suspect you are seeing the differnce between a MAF system and a speed density system. There is no MAF sensor on speed density as it is not using the Mass of the Air Flow (MAF) to run it. It simply is using the Manifold's Absolute Pressure (MAP) as the primary basis of the ECM processes. I'm over simplyfing it here, but thas lack of a MAF sensor on the snout of the throttle body i's the easiest way to tell them apart.
If you a have a MAF system now, there are many changes to be conducted, particularly on the computer side and some others on the parts side I don't know your level of knowledge on the issue, so please don't feel insulted by my saying that it's not just a question of removing the MAF and firing it up again. That won't work.
Maybe an anology is that we use both automatic and standard transmissions, which although similar to each other that they connect the engine to the rear axle, and have gears, they function differently and need different forms of input to make them work. MAF and MAP are not interchangable either.
Old May 21, 2006 | 07:20 PM
Zrunner90's Avatar
Transmission: M5
Ok I see what youre saying. I knew speed density cars didnt have a MAF sensor, but I was thinking there was a sensor in the same area (intake ducting) for speed density motors as there were for MAF motors. Thanks for the info.
Frozer!!!
Jan 19, 2024 04:55 PM
nuggie
Aug 25, 2015 01:27 PM
kyleb24
Aug 15, 2015 08:24 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
3rdgenparts
Aug 8, 2015 07:09 PM
