rusty fuel lines
Old May 23, 2006 | 02:15 PM
i8myz28's Avatar
Car: 86 z28
Engine: 355 TPI W/305 HEADS
Axle/Gears: 3/73's
rusty fuel lines
i'm in the middle of replacing my fuel pump and the sender lines are rusty( and i think i bent the feed line). so i'd like to replace the sender and the lines front to back. instead of trying to get factory lines is there a better or different way to replace these lines from the tank to the rail... any suggestions would greatly appreciated..... thanks in advance guys.....
Old May 26, 2006 | 03:10 PM
TKO500's Avatar
Car: 91 B4C, 17 C7 GS, 16 Denali DMax
Engine: LS3, LS3, LML
Axle/Gears: 3.23, 3.42, 3.23
You could replace them with high pressure rubber lines or find a good used sending unit.
I have a spare sending unit if your interested.
BTW: Your old 295 tires are not long for the world now... We are about to smolder them
Old May 26, 2006 | 08:27 PM
i8myz28's Avatar
Car: 86 z28
Axle/Gears: 3/73's
about time 4 the 295's
hey there, i am interested on the sender, how much do you want for it..? i need to know a.s.a.p.... thanks
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
