Distributor shaft part number?
Car: 91 Formula
Engine: 383 HSR
Transmission: 5th 700R4
Axle/Gears: 3.89
Does anyone know what the part number is for a dist. shaft on a 91 Firebird or similar model, I understand that you need to replace it to replace the reluctor ring on the dist.
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Can't help on the shaft part number, but you may consider a rebuilt dist from AZ or the equivalent. Around $100, the reluctor will be new and they should come with a new control module.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
# 10467353
1992 Trans Am
May 10, 2023 07:19 PM
IrocZ'85
Aug 17, 2015 06:24 PM
TA8487
Aug 16, 2015 12:21 PM
