TPS sensors
Old May 27, 2006 | 05:52 PM
83 scrambler's Avatar
Car: 83 CJ-8 (Scrambler)
Axle/Gears: (F)Dana60/(R)GMcorp14/locked 4.11
TPS sensors
quick question for you guys out there. I tested my TPS sensor and adjusted it. worked for a bit, and now the sensor output wire is up to 4.8 volts, causing the ECM errors. does anyone know the resistances and whatnot to test the sensor itself? i know all about the voltage output tests, but i want to test the sensor itself. couldn't find a good answer by searching. thanks
Old May 28, 2006 | 01:30 AM
robert1's Avatar
As far as I've read, it just has to have a smooth transition from idle to WOT. You check it with a voltmeter attached, and watch it climb. Why is 4.8 too high. I thought that it just had to reach a minimum of 4.5 or something. What was the idle voltage, and did you set the mechanical idle with the IAC disconnected first?
Old May 29, 2006 | 05:35 PM
because it is 4.8vdc on the sensor output with the throttle fully closed. the reference voltage is correct, but thew output is very wrong, and only one week after i adjusted it. what i am looking for is the method to test the sensor itself, with no voltage applied. any ideas?
Old May 29, 2006 | 09:30 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Mulitmeter with a bar graph to check resistance.
I adjusted mine a few weeks ago since I was getting a code 22 (I think it was 22, it's the Low Voltage at TPS error), after adjustment the code was more frequent and I have't had time to play with it more.
Old May 29, 2006 | 09:34 PM
any idea what resistance is within tolerance, and across which pins? i assume the sensor is just a rheostat (sp?) i know i have 6k ohms across 2 sets of pins, and one set (can't remember) is about 150, and doesn't vary much when sensor is moved through full range of motion. i think it changes of less than 50 ohms
come on guys i know someone out there has to have this little tid bit of information rattling around in their brain. really need to know. i am trying to get in touch with a manufacturer but that isn't going so grand
Old May 30, 2006 | 06:37 PM
any takers yet?
db057
Jan 10, 2020 08:55 PM
92firebirdguy
Sep 1, 2016 07:53 AM
bbsr72
Apr 2, 2016 09:12 AM
Fred SS
Oct 12, 2015 11:27 AM
BWilcox
Sep 20, 2015 12:19 PM
