Intake runner removal problem
Old May 29, 2006 | 01:27 PM
puffcat's Avatar
Car: 1988 Iroc-Z
Engine: 305 v8 tpi
Transmission: manual
Axle/Gears: posi
Alright, I'm trying to remove my passenger side intake runners. I've removed all 10 bolts and nothing else is holding it down. It seems the fuel rail is in the way and maybe something else, I can't really see this something else. Does anyone have any suggestions on how to get this off without removing the fuel rail? Because that seems like too much of a hassel.
Old May 29, 2006 | 02:04 PM
AussieGTA's Avatar
Car: Trans Am GTA
Engine: 350TPI
Transmission: T700R4
Axle/Gears: 3.45
Not remembering exactly how many bolts there are off the top of my head....Did you get the two bolts that hold the runners from the inside??
There is one bolt for each runner on the inside, there a PITA to get to. Once you have them out the runners will come out, just takes a little bit of tilting and pulling.
Old May 29, 2006 | 02:40 PM
camarojunkie77's Avatar
Car: 1977 camaro z28
I just loosen the 4 fuel rail bolts a bit and that will allow you to remove the runner.Dont forget to put thr runner back under the fuel rail before you tighten the rail down.
Old May 29, 2006 | 05:20 PM
puffcat's Avatar
Car: 1988 Iroc-Z
Engine: 305 v8 tpi
Axle/Gears: posi
Yeah I did get those pita bolts, I didn't know I could just loosen the fuel rail without messing anything up. Thanks alot for the help. Now to get to work on this thing.
Frozer!!!
Jan 19, 2024 04:55 PM
mdtoren
Aug 16, 2015 05:45 PM
3rdgenparts
Aug 8, 2015 07:09 PM
mustangman65_79
Aug 8, 2015 12:07 PM
