starting problem
Old Jun 7, 2006 | 12:21 AM
CRAZYCHUCK13's Avatar
Car: 91 Z28
Engine: 383-Carb
Transmission: TH400/3500 Stall
starting problem
hello again.
i have not visited in a while,very busy.
anyway my 89 5.7 takes about 3 to 4 crank trys before it stumbles to a start.
throttle response is inconsistant.upon starting can sometimes smell excessive fuel.sometimes starts on first try.can ayone help w/troubleshooting procedures.what are inj's supposed to ohm at & how do i correctly check.
thanks
p.s.
sometimes throttle response is right on.other times is sluggish.is it safe to say i have inj issues crazychuck
Old Jun 7, 2006 | 02:48 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Check for codes and check the basics.
Cap/rotor/wires/
Injectors could be on the way out, if u dont check them for leaks at the bare minimum ohm them out.
Coolant temp sensor going out of range etc.
U didnt leave us much to go on.
later
Jeremy
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
