slp intake runners
Old Jun 7, 2006 | 09:17 PM
66impalaTPI's Avatar
Car: 96 impala
Transmission: 4L60e
slp intake runners
Does anyone have a step by step process of how to install these things? The slp directions that came with the kit is not clear at all!
Old Jun 8, 2006 | 08:58 AM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
there basically the same to install as regular runners. You can call SLP for technical help. They are pretty good Just make sure you tighten the bottom and top evenly. do not tourge the bottom before you get the upper plenum in place. I had that problem and they did not fit right until I took them off and did it all over again. Do not forget to loosen the fuel rails bolts to slip the runners in, once you get the bolts started then Tighten the fuel rail bolts back up.
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
Rally Smith
Sep 14, 2015 06:59 PM
buckshot63
Sep 10, 2015 09:15 AM
toronto formula
Sep 10, 2015 07:31 AM
89fast5oh
Sep 8, 2015 09:55 AM
