TPI Runner Install
Old Jun 8, 2006 | 10:30 AM
LeonardS's Avatar
TPI Runner Install
I followed the FAQ information on changing my injectors. Now I need to re-install the runners. If I tighten the lower, inside bolts on the runners before installing the plenum, how do I keep the gaskets from tearing as I install it. If I install the plenum first, then how do I tighten the 2 inside bolts on the lower runners?
Many of you have done this, so I must be missing something.
Leonard
Old Jun 8, 2006 | 11:03 AM
jim91gta's Avatar
Car: 1991 GTA
Engine: 5.7
If I remember correctly, when I did it I did not tighten bottom. I put plenum on first and then tightend the inside bolts using an extension to ratchet. I think i also had to use swivel socket.
kickasscamaro's Avatar
Car: 1985 camaro z28
Engine: 305 tpi
which gaskets are you worried about tearing? put the gaskets on the manifold tightened down all the lower runner bolts, then put the gaskets on the top of the runners, and slide the plenum in. its a snug fit, just make sure the gaskets dont drop down at all.
Old Jun 8, 2006 | 11:05 AM
LeonardS's Avatar
The top ones are the ones I am worried about tearing. When I removed the plenum, it was a very tight fit and of course it tore the gaskets coming out. It didn't look like there would be access to the 2 lower bolts on the inside of the runners if I installed the runners first.
Old Jun 8, 2006 | 04:53 PM
MattODoom's Avatar
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
You can access the two "inside" bolts with the plenum on.
Just need a long extension and some fender guards.
Old Jun 8, 2006 | 08:13 PM
Guest
Guest
Posts: n/a
Yep, leave the bottom bolts loose and tighten them after you get the top ones started and somewhat threaded in.
Vintageracer
Jan 10, 2020 05:33 PM
Caspar
Jun 19, 2016 11:19 PM
mdtoren
Aug 16, 2015 05:45 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
