Need Cylinder Heads, Please Advise!
Old Jun 10, 2006 | 11:21 PM
mytagta's Avatar
Im planning on buying some new cylinder heads. Am i making the right decision. I want the most bang for my buck. I will also be purchasing some new headers. This seems like a good time to get some quick horsepower.
Heres what im looking at.
Eldelbrock Performer Centerbolt
  • Designed for 1987-95 Chevy 5.7L engines originally equipped with centerbolt valve covers (except Corvettes; see Performer Centerbolt for Corvette below)
  • 1987-95 intake manifold bolt pattern
  • High-velocity intake runner works with either T.B.I. or Tuned Port Injection systems
  • Maintains stock compression ratio when used with the recommended head gasket
  • Accepts stock centerbolt or Edelbrock aluminum valve covers #4246 and #4247
STREET LEGAL PERFORMER CENTERBOLTChamber SizeIntake Port SizeValve Sizes (in/ex)Bare (single)Complete (single)60cc165cc2.02"/1.60"#60849#60859
________________________________________________________________
AND HEADERS
Brand:EdelbrockProduct Line:Edelbrock TES Tubular Exhaust System Headers with Ti-Tech CoatingHeader Material:SteelHeader Finish:Ti-Tech ceramic coatedHeader Style:ShortyPrimary Tube Diameter (in):1 5/8 in.Collector Diameter (in):2.500 in.Tuned:NoPrimary Tube Gauge:16-gaugeCollector Attachment:Stock flangeFlange Style:StandardFlange Thickness (in):3/8 in.Bolts/Studs Included:YesGaskets Included:YesReducers Included:NoY-Pipe Included:YesQuantity:Sold as a kit.
Headers, Shorty, Steel, Ti-Tech Ceramic Coated, Chevy/Pontiac, Camaro/Firebird, 5.0/5.7L, Kit
Make your headers last with Ti-Tech coating from Edelbrock.
Boost performance and drivability in your vehicle with Edelbrock's Tubular Exhaust System headers with Ti-Tech coating. In some cases, you'll shave up to a full second off your 0-to-60 mph times, because the Edelbrock design improves your engine's ability to breathe. Mileage also will improve, because your engine becomes more fuel-efficient. Best of all, these headers give you all this performance with acceptable emissions levels. They accept all stock emissions equipment and are street-legal in all 50 states. The Ti-Tech coating features a C-105 titanium satin finish for heat stability up to 1600 degrees Fahrenheit. As the temperature rises the coating will cure, becoming harder and more abrasion resistant.
Im looking at around 1700 dollars Right Now . Am i going in the right direction. please reply befor i make a mistake.
Old Jun 11, 2006 | 02:40 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Check out Trickflows or the Patriot small block head.
I prefer those over the edelbrocks, least the chambers are a little more modern in my opinion.
Also the new AFR are supposed to be affordable and have phenominal flow numbers or shop around for AFR's in general.
Little off the wall, a cleaned up set of Vortecs would do well also.
later
Jeremy
Old Jun 11, 2006 | 02:38 PM
Don 79 TA's Avatar
Car: Hers: 88 Formula 350
Engine: TPI
Axle/Gears: 10 bolt Posi
i just bought the 60859's
i have to say, they look really nice
gaskets line up perfectly
nice and clean
i haven't installed them yet, but since i am not going crazy with a wild setup, they seem to be a nice replacement
the trick flows also seem nice too, and 56cc
just seemed like the e-heads fit better for our needs, and all sensorts and what not are supposed to fit perfectly too
i should start this project in another week or so, and they are very light
i bought the mr gasket .028 head gaskets and crane thin bodied rollers, and proform rocker covers
should be real nice when it's done
Old Jun 11, 2006 | 09:51 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
ive done some resurch on this my self.
AFRs are great for 1400, and trick flow has the cnc combustion cham. for about 50bucks less. these are the best ive come across.
Old Jun 12, 2006 | 01:03 PM
scamaro355's Avatar
Car: 92 rs
Engine: 355 stealth ram, dart heads, S480
Transmission: 4L80E
i purchased a set of heads about 2 weeks ago i looked all over for the afr's but it seems like everyone that carries the 195 had them on a 8-12 week back order. I ended up going with the dart iron eagle platinum 200cc they flow 275 cfm @.500 and 243 @.400 which is higher than flow than the afr's unless you want to drop close to 1800.00 for the competition port job with them.The best part about the head was summit had them in stock and i had them in 2 days came to 1085.00 that was to my door
Old Jun 12, 2006 | 02:12 PM
conlinj's Avatar
I'd stay away from teh edelbrock headers, really small primaries. Go with hooker 2055's or some slp's. You really should pick your heads to match your cam and vice versa. If your not changing the cam, you don't need big heads. Have you or do you plan on changing cams at the same time?
-Jim
Old Jun 12, 2006 | 08:47 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
that is really good, are they assembled or bear.
the only thing is the large intake cc my cause a loss of bottom end torque. for a tpi setup that revs to 5500 rpms and is 350ci a 180cc is good and 195 would be pushing it.cam chose is the key there.
Old Jun 12, 2006 | 08:56 PM
scamaro355's Avatar
Car: 92 rs
Transmission: 4L80E
that was fully assembled as far as the intake size im running the stealth ram my cam is nothing huge by any means its the lt4 hot cam 218 intake 228 exhaust with a .525 lift on both sides im shooting for 350-375hp at the wheels ill prolly need a lil bigger cam to pull it off but time will tell
Old Jun 13, 2006 | 11:06 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
sweet sounds like youll get that easy with that setup.
but i think for this guy some of the dart 180cc heads will be great for his stock motor.
but imo if you have 1700 bucks to spend , id get a full exhaust,msd,afpr,and k&ns.not that the heads wouldnt help alot.
good luck
Old Jun 15, 2006 | 12:14 AM
Leif-o's Avatar
I've got a pair or Dart Iron Eagles assembled good to .600 lift with a hydraulic roller cam. If interested the ebay auction is:
eBay Motors: Dart Iron Eagle Heads!!!! Less than 100 miles!!!! (item 8074236470 end time Jun-17-06 00:20:02 PDT)
Old Jun 16, 2006 | 08:34 PM
scamaro355's Avatar
Car: 92 rs
Transmission: 4L80E
those are are WAY to big for what he's looking for
Cornholio7979
Sep 20, 2018 02:31 AM
Chuck84TA
Jul 15, 2016 09:05 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
NinjaNife
Aug 23, 2015 11:49 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
