48mm or 52mm on 88' 5.7 tpi, how can i tell?
Old Jun 12, 2006 | 11:38 AM
WILL85IROC's Avatar
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
how can i tell if i have a 48 or 52mm throttle body on my 88' 350 tpi??? are there any numbers or codes or do i simply measure it? if so, where do i measure?? thanks
Old Jun 12, 2006 | 12:56 PM
Guest
Guest
Posts: n/a
Measure it (where the plates are would be easiest and not require removal), but if its stock, its 48mm.
Old Jun 12, 2006 | 05:32 PM
pmpn's Avatar
Car: 1989 GTA
Engine: 5.7 TPI
Transmission: A4
the stock 48mm is usually cheap casting. Most aftermarket TBs have decent to nice finishes.
Old Jun 12, 2006 | 05:58 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
ok, i just measured the rear of the TB and im getting 50mm for each blade????
the casting #'s are '17075921' on the bottom and '17085051' on the side....
theres also '1835 huy' on the side also...
am i measuring correctly when i measure the back instead of the front??? i went across each blade and not directly across the entire face, end to end... thanks
Old Jun 12, 2006 | 06:19 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
i think its a 48mm but not sure, here are a few pics:
Attached Thumbnails 48mm or 52mm on 88' 5.7 tpi, how can i tell?-100_2065.jpg
Old Jun 12, 2006 | 06:21 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
one more...
Attached Thumbnails 48mm or 52mm on 88' 5.7 tpi, how can i tell?-100_2071.jpg
Old Jun 12, 2006 | 06:23 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
here are the #s on the side and bottom
Attached Thumbnails 48mm or 52mm on 88' 5.7 tpi, how can i tell?-100_2067.jpg
Old Jun 12, 2006 | 06:49 PM
Guest
Guest
Posts: n/a
IIRC there's a larger machined area at the back side, you need to measure more where the blades are or the blades themselves. Looks stock to me though.
The numbers are just GM part numbers, so that tells you it was/is a stock throttle body and the only way it would be anything other than 48mm is if someone bored it out larger than 48.
Old Jun 12, 2006 | 06:58 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
IIRC ??? whats that mean?
Old Jun 13, 2006 | 07:57 AM
pmpn's Avatar
Car: 1989 GTA
Engine: 5.7 TPI
Transmission: A4
Thats 48mm TB.
Old Jun 13, 2006 | 08:02 AM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
ok thanks, looks like ill be selling it, need to upgrade to a 52mm
Old Jun 13, 2006 | 09:21 AM
Roads88's Avatar
Car: 1988 Pontiac Trans-AM
Engine: TPI 350 (5.7L)
I went through these guys and it works well:
eBay Motors: TPI 52mm bored/port throttle body 85-92 Z28 TA Corvette (item 8072670660 end time Jun-15-06 18:58:24 PDT)
I had them rebuild and rebore mine.
diana227vegas
Jul 8, 2016 12:27 AM
stalkier
Dec 6, 2015 11:25 PM
777Shock777
Oct 29, 2015 04:30 PM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
