knock sensor relocation?
Old Jun 14, 2006 | 02:42 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
my buddy recently swapped headers on his TPI application to blockhuggers for ground clearance issues, and he could not get his knock sensor to fit anymore. He put it in the cylinder head but its not really picking up anything. is there anything else he can do to retain the sensor?
Old Jun 14, 2006 | 02:59 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
The sensor needs to be in the original location to be able to pick up if there is a knock. You may be able to relocate to the opposite side of the block but he may have to use different headers or modify the headers to clear the sensor.
Old Jun 14, 2006 | 03:03 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
thanks both sides are pretty tight so i guess he wil probably just not use it.
Old Jun 14, 2006 | 03:12 PM
Ughh61's Avatar
try the motor mounts
drill and tap for it
you will get a reading there
Old Jun 14, 2006 | 03:21 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
you serious?
Old Jun 14, 2006 | 03:27 PM
Ughh61's Avatar
ya thats what alot of people do when they do the s10 v8 swap
when they use the tight headers
there is more room on the mount on the s10 setup
but the priciple is the same
Old Jun 14, 2006 | 03:28 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
thank you i will let him know.
Old Jun 14, 2006 | 03:37 PM
Ughh61's Avatar
ya there a few books on the s10 v8 swap that say you can do it
vibration does traval good though metal
so i dont see why it wont work if it in solid and its on the side of the block on the mount (no rubber mount between it and block ) of course
Old Jun 14, 2006 | 04:47 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Should be able to put it just about anywhere on the block.
Old Jun 15, 2006 | 02:27 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
well like i mentioned above, he put it in the cylinder head but he could hear pinging now that previously couldnt hear. he hasnt hooked up a scanner yet to see if its detecting but im quite sure its not.
Old Jun 15, 2006 | 03:09 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It might take some experimentation to get it working right. The knock sensor is pretty sensitive to how much torque is used when it's installed, how much and what kind of sealer is used on the threads, etc.
Old Mar 24, 2008 | 05:53 PM
AC's Avatar
AC
Car: Used to drive a camaro
Re: knock sensor relocation?
I'll resurrect this one from beyond. I recently had gotten some advice because of some issues I'm having to relocate the KS onto the intake manifold. My concern there is the KS is tuned for a certain frequency. Having it that far away from the ara of knock and into aluminum for that matter I'm sure will change the accoustics of knock.
Thoughts? Experiences? My issue is when datalogging I have a "sawtooth" pattern to my knock counts THROUGHOUT ANY datalog I do. Starts immediately and continually climbs up to 60k counts, drops to 0 only to repeat indefinetly, appearing as a sawtooth pattern in Tunerpro's histogram.
My block is street filled (up to first freeze plug) and I'm using red RTV on the threads.
Old Mar 24, 2008 | 06:41 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Only thing I could think of to do to blindly tune this knock sensor is to mess with the torque at which it is installed and see if you get any different readings.
Old Mar 24, 2008 | 08:24 PM
AC's Avatar
AC
Traviz, the stock location right? I may have F'd up my threads a bit when I did it because orignally the guy who prepped my block (align hone, bore, etc) also did my street fill and didn't take into account I might run the knock sensor on the driver side. SO, there was a plug there that I couldn't back out so I had to drill it out. When I did ofcourse there was ceramic block filler behind it and I might of goobered the threads a bit. The sensor does install fine it seems but I'm hestitant to go in and try to wrench it down more...
L98GTA87
Oct 19, 2015 10:43 PM
spartanreaper
Sep 25, 2015 07:22 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
