Fuel pressure stuck
Old Jun 20, 2006 | 06:09 PM
ThUnDeR2005's Avatar
Car: 1990 Camaro "RS"
Engine: 355 TPI
Axle/Gears: 3.23 LSD
Fuel pressure stuck
Ok so my car has a BBK AFPR and when I had it on the dyno last week, it just wouldn't change fuel pressure. No matter what adjustment was made, with vacuum disconnected, it would stay at 45 psi. Now... I'm assuming this means it doesn't work anymore. So heres my real question...
I'm looking at other AFPRs and I've seen a few where they say you reuse the diaphragm and spring and uses a new housing? Like crane and the other BBK. Are these something I'd need to avoid? I can only guess my AFPR quit working because the spring/diaphragm is messed up. Can someone point me in the right direction as to how these things work? Lol Thanks
Old Jun 27, 2006 | 11:08 AM
Vader's Avatar
Did you reconnect the vacuum line to the FPR? Just asking...
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
