How can I tell what EGR solenoid I need?
Old Jun 20, 2006 | 09:35 PM
PneumaticTire's Avatar
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
My current one does not have the part number that GM wants to know. Apparently there was two kinds for 1986 305 tpi engines. I believe my current one is already an aftermarket one. So whats the difference between the two? I'm sure SOMEONE has ran into this before and knows the answer to this. THANKS!
Old Jun 21, 2006 | 11:51 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Aftermarket replacement egr valves come with a selection of shims to be installed to match the OE valve. You may be able to tell which replacement shim that you need to install in your new valve by removing the old aftermarket valve and looking for the decimal number stamped on the shim. The hole sizes and thickness of the shims will vary and you should be able to match it even if the shim isnt stamped.
Old Jun 21, 2006 | 12:46 PM
Thanks for that info, but it's the EGR solenoid I'm wondering about. My EGR valve is a new AC delco unit that I put on about 1 month ago.
Old Jun 21, 2006 | 02:53 PM
Wadebryant's Avatar
Sorry about the rabbit trail....misunderstood.
If your 8th digit in the VIN is F and you have a 305TPI motor, the egr solenoid that you need is DR631 and the part number is 1997169. Retail through GM is $53.97, wholesale is about $37.79.
Hope that works for you! If not, contact your local GM parts dealer, have your vin info ready to assist.
Old Jun 21, 2006 | 05:53 PM
THANK YOU SO MUCH FOR THE INFO! That is EXACTLY what I needed. I did call a dealer, and he asked me what letter my 8th digit was and I told him F, but he still was unsure cause 2 were listed. I'll give them this number. THANK you again. WIsh me luck, I hope this fixes my code 32, since my EGR valve, temp sensor, and vacuum lines are all new, lol.
Old Jul 23, 2011 | 05:37 PM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
Re: How can I tell what I need?
do you know the part for a 1983 crossfire EGR solenoid and who has it in stock?
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
meeklay812
Oct 1, 2015 03:46 PM
