Noob needing help with questions about tbi tpi swap!!
Old Jun 22, 2006 | 10:17 PM
drshirk's Avatar
Car: 91 Camaro RS Convertible
hey all,
I have a 91 camaro 305 tbi that I want to put a 350 into. I am building the 350 myself so I can learn how to do it. I have several questions about tpi.
I have an 88 firebird that has a 305 tpi engine. Can I take the tpi setup off of this firebird and put it on my new 350 engine? Will this work? What all will I need to do to get it to work? Please be specific so I can understand everything I will need. What is the difference between MAF and speed density? I read that MAF limits HP to under 350. Is this true? If so is there a way to convert it to speed density? I appreciate anyones help with these questions. Because it is so new to me it gets very confusing sometimes. I will be searching here on the boards and researching but you guys are always so helpful and very knowledgeable so please keep the info coming on this one. I need all the help I can get.
My 350 will have this camshaft.....
http://www.powerandperformancenews.c...Category_Code=
and dart iron eagle s/s heads http://www.dartheads.com/chevysh.aspx
I will be adding a good exhaust and headers off of the 88 firebird. assuming they will fit.
Old Jun 25, 2006 | 04:27 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Check the tech articles for how to convert TBI to TPI. Its not 100% perfect but it will help. There's also one on converting MAF to MAP.
You'll need a new air intake in front of the throttle body, as the 88 one will have a MAF sensor in it, and you dont want that in front of your engine, you dont need it.
Old Jun 25, 2006 | 09:08 PM
drshirk's Avatar
I read the tech articles but will it doesn't say much about if I am using a tpi setup from an 88 thirdgen can I transfer it to the engine that I am building using everything from the 88 car. Like will the wiring harness work from the 88? It looks like I will need to get a custom chip burned. Will this be all I need or will I need other parts. I have just purchased an 88 parts car that has a 305tpi so I just want to take the tpi off and and transfer it to my new engine.
Old Jun 26, 2006 | 11:32 PM
Kevin91Z's Avatar
This isnt something I can walk you thru over the internet. Its also not something a new mechanic can do on his own. You're going to need to find someone near you who can help.
Good luck!
Old Jun 28, 2006 | 10:17 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Yes.
Assuming you will be transferring everything from the 88 Formula (ECM, harness, fuel pump, sensors etc.), you'll need to have a new PROM burned, along with larger fuel injectors (or just obtain them from a donor L98, to allow things to run smooth, initially)...
MustangBeater20
Oct 29, 2022 09:20 PM
IROCZ1989
Jan 24, 2016 03:55 PM
jharrison5
Aug 19, 2015 05:53 PM
reiderz iroc
Aug 13, 2015 04:57 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
